What kind of sauna has an operating temperature over 90° C?I am planning to use this cable because the rating is 200* C and it is going in to feed the sauna.
The typical temp inside the sauna is over 90* C so I am getting the seal tight that rated over 90* and this is the only high temp wire that I can get.
Am I thinking correctly or I am missing something?
90° C = 194° F so it should be okay. Are you actually running the wires inside of the sauna?HUUM is the manufacture name and they are claiming that the temperature inside the room can reach 180 and above.
It will require a 0.29 ampacity correction for a 180°F ambient.so THHN wire will do the job ?
Yes it looks like a cocoon filled with stones in the corner of the room and the space about 3’ to the closest wall. I am afraid that the liquid tight will not handle the temperature90° C = 194° F so it should be okay. Are you actually running the wires inside of the sauna?
1.3mmWhat is the outside diameter of the cable?
1.3mm it is an individual wire #8 type SAWhat is the outside diameter of the cable?
No contactor??? The full current shouldn't have to enter the sauna.so the #8 thhn with the temperature correction is about 40 Amp?correct
yes there are 2 contactor that supplying power to the saunaNo contactor??? The full current shouldn't have to enter the sauna.
