725.3 Other Articles. Circuits and equipment shall comply
with the articles or sections listed in 725.3(A) through (N).
Only those sections of Article 300 referenced in this article
shall apply to Class 1, Class 2, and Class 3 circuits.
(A) Number and Size of Conductors in Raceway.
Section 300.17.
You find the diameter of the cable you are using, then calculate the area and use the information in Chapter 9 Tables 1 and 4.Hi,
I was looking for some information on how to size conduit for Cat 6 cable. Does anyone have an literature on this or how to do it. I am very familiar with sizing conduit for standard conduits with the values in chapter 9.
Thank you.You find the diameter of the cable you are using, then calculate the area and use the information in Chapter 9 Tables 1 and 4.
Also some manufactures of those types of cables have instructions that specify a maximum conduit fill, and those often show less cables than was the Chapter 9 calculations would permit.
See 725.3(A).View attachment 2559010
Since they don't appear to be referenced in article 725, I am not sure this is required, although it is probably as good a place to start as any.
They make special ducts to carry such cables. They might be a better choice than standard conduit.
725.3 (A) refers to 300.17.See 725.3(A).
The rule in 300.17 is a generic performance rule and the Informational Note sends you to the prescriptive rules in the raceway xxx.22 sections and the xxx.22 sections sends you to Chapter 9725.3 (A) refers to 300.17.
300.17 does not reference chapter 9.
The informational notes are not enforceableThe rule in 300.17 is a generic performance rule and the Informational Note sends you to the prescriptive rules in the raceway xxx.22 sections and the xxx.22 sections sends you to Chapter 9
Of course not, but the rules that the Informational Note tells you to look at are.The informational notes are not enforceable
