Conduit fill
arnettda
I am running a 250-250-3/0 USE cable with a RHW-2 ratting plus ground in a pipe roughly 60ft under a house slab and comming up into the service panel. I am trying to size the PVC pie for it. I used chapter 9 tables 4 and 5 to determine the size. 355.22 tells me to do this. Is there anywhere else in the code that talks about conduit fill and cables? Or just the respective pipe code articles?
I think you have a problem. First off if conductors in parallel are installed then you must count each conductor in the pair as a ccc. 310.15(B)(3)(a) last sentence first paragraph.
Now assuming the neutral is not a CCC you have 6 conductors and must derate 80%. 250 MCM RHW-2 is rated 90C both wet and dry so the ampacity is rated 230. 230*3= 690 * .8= 552 so you can go to 600 amps as long as the calculated load is not over 552. Now I calculated the fill and got 3.5"
RHW-2 without an outer jacket
250 KCM = .4596*6= 2.7576
3/0 = .3117*3 = .9351
2/0 + .2624 *1 =.2624
Total is 3.9551 = 4" schedule 40 PVC 5.022... 3.4" pvc is only 3.985
I am sorry I should have been more clear. I am going to run each set of wires in a seperate conduit. I believe this should be oaky. Direst buried in trench and then into pipe.
Your resposne did make me realize I was using RHW-2 with outer covering. I believe outer covering is something completly over the normal RHW-2 insulation?
Your resposne did make me realize I was using RHW-2 with outer covering. I believe outer covering is something completley over the normal RHW-2 insulation?
Then you only need 2.5" PVC. I am not sure what the outer covering is about. If that is what you have then the 2,5"PVC will work
My instructor in a code class I took one time talked about it but that is all I remember was him discussing it and saying it was something extra.
Sorry, I can't resist - Is the pipe buried 60 ft deep?:)
tables 4 and 5 is all that is needed, once actual conductor sizes have been determined, multiple current carrying conductors in same raceway may require adjustments and require larger conductors as has been brought up.
I also come up with 2.5 inch for conductors without outer covering, but you will need 3 inch if there is outer covering - not sure just what outer covering would be as I don't think I have seen such conductor before. you could measure your conductor and see how it compares to dimensions in table 5 if you are not sure what you have. Would need a reasonably accurate caliper or something that will measure to .001 inch increments.
