npattison
- Washington
The question is how many 1" lock nuts are required (per NEC) to connect two metallic enclosures via 1" rigid conduit, 6" in length?
I've typically seen a total of 2 locknuts; one per the inside of each enclosure. One inspector has required 4; one on the inside and one on the outside of each enclosure. Can anyone shed some light on this? Each metallic enclosure is bolted down and will not experience the outdoor elements.
