On one of our projects we installed PVC conduit to feed some floor boxes. The iron workers add installed the rebar in the slab as usual. However at the areas of where a control joint was to be cut after the slab hardened, the iron workers had to have their rebar not attached if you will and it would slide through PVC that was greased so it could move. At the same locations of the sliding rebar and control joint, the electrical inspector had us install expansion couplings at these locations. At the time I was rushed and did not hesitate. I can't find any thing in the code for us to install a expansion fitting or coupling at a control joint. This is NOT an Expansion joint. Your all thoughts would be greatly appreciated.
