Conduit Install
Alwayslearningelec
NJ
Estimator
Anyone have experience installing FRE conduit in the ground? 4 inch I’m curious as to what your experience was installing it as it weighs less than PVC.
Yes. It’s glued with epoxey from a special caulk gun. Epoxey type varies with temp. Cut lengths need to have end sanded with emery. Plus epoxey needs to dry before pulling
But it’s very strong, super easy to pull thru. In ground may not be best use, would be great on exposed runs on bridge or similar
Why would inground not be so good? Installs faster than PVC?
