mstrlucky74
- NJ
Is there a code section for this? Thanks
Labels are not markings in terms of the demands of 110.21 or the .120 sections of the wiring methods.
Guess the OP needs to be more specific....are you talking about Markings or Labels?
Sent from my SAMSUNG-SM-G935A using Tapatalk
What the spec' is referring to is not a Code requirement.Have to read 110.21... I'm talking about specs saying to label conduits every 15' or any other footage.
That is not part of the NEC....you have to comply with the requirements of the contract documents. Those documents should tell you every thing you need to know about the labels they want to see on the conduits.Have to read 110.21... I'm talking about specs saying to label conduits every 15' or any other footage.
I agree and I think that is what the OP is asking. Some spec's want the conduits field marked with things such as voltage, panel origin, or type of system (i.e: fire alarm, power, lighting, BMS, A/V etc.). We have also installed factory colored EMT for system identification.
