IRAM
New member
- Muscat, Oman
I have 405 Kilowatts Asynchronous Inverter duty motors to run with 380 volts variable 415 volts 3 phase supply power factor average is. .87, what size in mm conduit I can use to run this all industry and please also tell what size MCCB I can use in main distribution panel which is direcly connected to feeder ?
Here I am going to buried conduit directly in the earth normally temperature 40 degree maximum open air and main distribution panel is 45 meters far from feeder, kindly needed experts suggestions:angel:
