I have always thought the code did not allow mounting conduit-pvc etc to fences. I bid a job and was told the other electrician was going to mount the conduit to the fence. Am i wrong?
I can see the little stick-in-the-ground decorative fenced not being considered structures.
But if you gotta dig holes, or drive posts into the ground, in order to build a fence, it's a structure IMPO.
The short fence, to me, is not a structure. The tall one is.
Working in an area where it is impossible to dig deeper than 8-10 inches, tons of bolders and bed rock, no big ol tractor access. One idea was to run pvc along the bottom of a wooden fence that has a horizontal 2x6 plank at the bottom and cover with dirt bark lanscape etc..
With that kind of fence (the big one), I like running the PVC on top of the lowest horizontal rail, between the slats and the posts.
If it's a property line fence you could have some problems. Let's say that the fence is built 6" onto your property because the neighbor didn't want to help pay for it, then you own both sides of the fence and he would not be allowed to attach to it, but if it's a true property line fence then what you do one your side is up to you.
so if the fence is completely on HIS side, or its a property line fence, he is fine. If its completely on the neighbors side, then he cant attach anything to it. Correct?
~Matt
300.4(d) ??with that kind of fence (the big one), i like running the pvc on top of the lowest horizontal rail, between the slats and the posts.
300.4(d) ??
If it did not grow there it is a struture.
Even that little fence was 'built' by someone.
It would be funny to see a 2" feeder on that small fence.
Then you would have 300.11(B). :grin:It would be funny to see a 2" feeder on that small fence.
