What is the best way to leave an opening for pvc conduits in poured concrete walls?
M miamille New member Nov 7, 2009 #1 What is the best way to leave an opening for pvc conduits in poured concrete walls?
Pierre C Belarge Senior Member Location Westchester County, New York Nov 7, 2009 #2 Sometimes I see PVC sleeves through the wall, sometimes I see styrofoam placed in the form. Then again, I see a lot of core-boring too.
Rockyd Senior Member Location Nevada Occupation Retired after 40 years as an electrician. Nov 8, 2009 #4 Foam block-out is probably fastest, easiest, most economical way, but may not meet spec for the wall.
iwire Moderator Staff member Location Massachusetts Nov 8, 2009 #5 In formed walls I use PVC sleeves, fast and easy. In poured decks I use Styrofoam.
