Both 225.7 and 230.8 have the following requirement for sealing raceways.I don't think this is a code question. I don't think the code cares. It could be caulking.
Sealants shall be identified for use with cable insulation, conductor insulation, bare conductor, shield, or other components.
Yes but the op is talking about sealing RGS to the building. Cable, conductors, and conductor insulation are not involvedBoth 225.7 and 230.8 have the following requirement for sealing raceways.
Are you sure? I don't think that you're correct but I've been wrong before.Yes but the op is talking about sealing RGS to the building. Cable, conductors, and conductor insulation are not involved
Well that's the way i read it. Maybe I am wrongAre you sure? I don't think that you're correct but I've been wrong before.![]()
The NEC does not require that the entry into the structure be sealed...just that the interior of the conduit be sealed. The question is asking about the sealing required by the NEC.Well that's the way i read it. Maybe I am wrong
Correct my question: how to seal around the rigid conduit penetration when the conduit pass through the building exterior concrete wall from outside. What's type sealant can used in this case?The NEC does not require that the entry into the structure be sealed...just that the interior of the conduit be sealed. The question is asking about the sealing required by the NEC.
You were correct!Yes but the op is talking about sealing RGS to the building. Cable, conductors, and conductor insulation are not involved
We always use mortar. You can use silicone, phenoseal, or some other type of caulk. IMO duct seal won't keep the water out.Correct my question: how to seal around the rigid conduit penetration when the conduit pass through the building exterior concrete wall from outside. What's type sealant can used in this case?
why need to seal inside conduit? NEC requirement? Just curious...So to clarify:
Outside of the conduit, to seal the conduit to the building, you can use mortar, silicone, phenoseal, or caulk. You can even leave the penetration unsealed, depending upon the circumstances.
Inside of the conduit: duct seal.
Yes when it goes from outside to inside the conduit is required to be sealed to prevent air from moving within the conduit. {300.5(G)} also what Winnnie stated.why need to seal inside conduit? NEC requirement? Just curious...
Love this forum, learned a lot !!!Yes when it goes from outside to inside the conduit is required to be sealed to prevent air from moving within the conduit. {300.5(G)} also what Winnnie stated.
As Don stated this is not an NEC question. Penetrations through the building envelope would be covered under something like the building code.Correct my question: how to seal around the rigid conduit penetration when the conduit pass through the building exterior concrete wall from outside. What's type sealant can used in this case?
