First of all i posted this in the NEC forum i guess i should have posted it here, also I am not sure this is a parallel circuits issue
I have a question, for an application with a shunt trip CB, in class 1 division 2;
Running the low voltage 120v and high voltage 480v in the same conduit
The CB enclosure has only two entries for the incoming power and supply to the building,
In past application I have installed a tee just after the union and seal to branch off for the trip supply, to keep control separate from power
My question is can I run the 120 volt for the trip in the same conduit, I have been reading under parallel circuits, and not sure if this will be acceptable for this application
What section can I find this information
Thanks
Thanks
