How often is required a pullbox on horizontal run of conduit
raider1 Senior Member Staff member Location Logan, Utah Nov 12, 2009 #2 The NEC does not have any specified distance at which a pull box must be installed in a straight run of conduit. Many engineering specs have a distance of 100' before a pull box must be installed. Chris
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Nov 12, 2009 #3 You need a pulling point once you've reached 360 degrees of bend in the run. If the run contains less than 360 degrees worth of bends there is no limit to the length of the conduit run.
