Neoeclectic
- USA
- Contractor
Hi everyone,
I have a conduit question.
I need to run CAT6 riser cables and it seems the only way to do it is to run a conduit along the wall outside to get from the structure on the left to the building. I don't want to waste your time with the long winded explanation of why we can't just bore straight through the walls (basically we can't).
I noticed that someone else previously used ENT which you can see in the image in the upper left corner. I always thought this was an improper way to utilize ENT. The other conduits you see are for lighting.
It this an acceptable use case for ENT? If it is then that's what I would want to do because it's simple.
If utilizing ENT this way is against NEC guidelines what would you suggest to use as a conduit? My main concern is that the conduit will be exposed for about 15'-20'.
And also, can a UL rated liquidtight be an acceptable conduit to use?
Thank you!
Thank you!
