rjwolfe
New member
- New Jersey
Is it allowable to support electrical raceways from supports of other systems?(Plumbing, Sheet Metal, etc.)If not, where is that addressed in the NEC?
I'm sorry but I really think that requiring that supports not be used to support more than one crafts work is completely bogus. Most all-thread rod is not listed by UL for any purpose at all. A two by four can be used to build a listed assembly but it is not itself listed. The logical extreme of that veiwpoint is that no structural component can support both a pipe and a cable. It is just absurd.Originally posted by bphgravity:
Usually not. Conduit supports varies to the specific type of conduit or raceway system you are installing. The code does require that raceways not support other equipment or wiring per 300.11(C) of the 2002 NEC. The problem is listing. Other support systems are usually not listed to support electrical equipment. Go to 300.11(A)(B)&(C) for specifics.
