d_amp
New member
- CA. Kern county
Where in the code book does it state, "Any conduit, less than 3' but greater than 18", requires a strap/support."
It only said that in the 2008 NEC. Previous and newer editions require the raceway to be supported no matter how short it is.Where in the code book does it state, "Any conduit, less than 3' but greater than 18", requires a strap/support."
Thanks for being thorough. TN is still stuck in '08 and I sometimes forget to go back to the furtureIt only said that in the 2008 NEC. Previous and newer editions require the raceway to be supported no matter how short it is.
How am I supposed to put a strap on a close nipple, offset nipple, or chase nipple?
Obviously there is a practical consideration for cases when the conduit termination is a suitable support.
I have no idea, but that is what the code rules require. The CMP does not seem to understand what their rules actually mean, as this issue has been addressed with proposals a number of times and nothing has changed.How am I supposed to put a strap on a close nipple, offset nipple, or chase nipple?
I submitted a public input for the 2017 to say that the conduit termination could be used as the required support where the conduit is 36" or less in length and it was rejected because conduit terminations are not supports.Obviously there is a practical consideration for cases when the conduit termination is a suitable support.
An observation - even pointed out by an inspector back when I was in a CEU class that was covering 2008 NEC, was that if you had two enclosures on the wall with a 4 inch GRC nipple between them (be it 6 inches long, 18 inches long, 36 inches long or even 48 inches long - if you placed a strap or clamp on that nipple, does it really support anything?The NEC has waffled on this one for the past 8-10 years, once reducing the requirement to nipples over 18" and then going back. IMO it is dumb to require a strap on a 6" nipple between two enclosures when you can have up to 3' of unsupported EMT, RMC, etc. between the box and the first support.
You can come in with a 8 pound hammer and start beating and the strap/clamp likely gives up long before there is any compromise to the 4 inch RMC.
