Re: conduit support
It is common knowledge to not mix pipe and conduit on common supports.
Pipe with pressure hammering will damage conduit, particularily EMT. The vibration of pipes under varying pressure can eventually damage insulation from the constant movement.
I don't know of anything in the NEC, but this subject is likely covered in other codes such as mechanical.
