1. In CMU wall area, we installed rigid conduit toward door opening under situation which we don't exact door hardware(door contact, EPT, EM lock) location. After that how can we install conduit inside door frame for connecting to door hardware ? (I am planning to install flexible conduit type & FMT 90 degree connector inside door frame up to door hardware location. and then mortar will be filled between door frame and door opening. Can we do that?)
2. In any wall area, door frames don't have junction box welded to door frame. Do you guys know how to install conduit & cable for door hardware?
In spite of that ACS is low voltage system, Should be it affected by NEC strictly? If you have a lot of experience about Door hardware or Access Control, Please give me good recommendation.
