Hello everyone:
What type of conduit recommended for above floor indoor pool area application? I know the nonmetallic type (PVC) or PVC coated metal conduit will be good choice but is IMC or Rigid Metal Conduit will handle this corrosive environment? Thanks,
I would stick (no pun intended) with PVC. I've seen too many corroded metal conduits in areas subject to the pool chemicals.
You could use a coated metal conduit but that would be pricey.
Does PVC sch. 80 last for a long time or it comes a part at the joints after a long time of installation?
If the proper application of the PVC solvent is used the joints should be good. The only time I have seen joints come apart were if the solvent wasn't applied correctly, wrong solvent used, or when used outdoors in a vertical position and no expansion coupling was used for the conduit when it emerged from the ground.
As far as the PVC lasting, IMO, it will outlast the metal conduit.
