It wouldn't be a bad idea to seal them. Keep the critters out, or if there is great difference in temps between the two spaces that they terminate in.Do conduit drops from the attic to living space need to be sealed at either the top or bottom?
These conduits are for Cat 6 cabling in residential construction.
Thanks
I did the same... More for small critters (bats in particular) than heat transfer, but it's also one of those "makes home inspectors happy and less likely to spot something else" when I go to sell in however many years.It wouldn't be a bad idea to seal them. Keep the critters out, or if there is great difference in temps between the two spaces that they terminate in.
