DWooD99!
- Dalton, MA. 01227
- electrician
I have a Conex shipping container with 480V 3ph incoming that feeds a 200amp Main Breaker. Then out of the main panel are three 3ph breakers that feed #1: main control panel that has a transformer that knocks down 480V to 120V for a PLC, than a second smaller 120V down to 24V for control wiring...the neutral (grounded) is tied with the ground at the secondary 120V connections. #2: A 30amp breaker to the air compressor is 480v and has a transformer inside to 120V for control wiring. the whole Conex frame is bonded to ground at the main panel. Then #3: A 100AMP breaker goes to a 10KVA transformer to knock it down from 480V to 208Y/120V, for lighting and control panel. The neutral and ground are tied at XO here.
Question I have is this:
Does the code says this is a separately derived system to be kept separate? .Because you may have the potential to have dangerous voltage differences between systems... so how do I keep the systems separate and where do I separate the neutral and ground so the secondary voltage at the 208Y/120V lighting and control panel is safely grounded?
