- Massachusetts
In this thread Stranded wires under screws it was brought out that there is a conflict between the UL General Director information and a manufacturers literature regarding stranded wire and devices.
From the 2008 general directory
snip..
Now looking at Pass and Seymour's literature for their CR series receptacles they say only solid conductors may be used.
From HERE
To me this is a big problem, can anyone explain what is going on?
RECEPTACLES FOR PLUGS AND
ATTACHMENT PLUGS (RTRT)
GENERAL
This category covers general use receptacles for use in wiring systems
recognized by ANSI/NFPA 70, ‘‘National Electrical Code’’ (NEC), and
outlets for use in appliances and fixtures. It also covers some attachment
plugs, male inlets, and cord connectors with nonstandard slot or blade
configurations which are part of a line of wiring devices including receptacles.
Other similar attachment plug devices are covered under Attachment
Plugs (AXGV).
snip..
Terminals of the wire-binding screw, setscrew, or screw-actuated back wired clamping types are suitable for use with both solid and stranded
building wires.
CR Series: #14 – #10 AWG solid side wire only. BR Series: side and internal screw-pressure-plate back wire capable of accepting #14 – #10 AWG solid or stranded copper or copper-clad wire.
From HERE
