Smatthew 219
- San Francisco, CA USA
So the first pic is from a text that I have for an apprenticeship and the other is from the NEC 2008 code book. I hope they appear in the post. If not please view under post (I'm new to the site).
The text shows that it's "OK" to run 300 amps through 2/O wire, 405 through 4/O, etc. without specifying what type wire it is. But as far as I can tell from the NEC code that is way off, no matter the type.
NEC says that only 260 through the most tolerant type 4/O and 190 through 2/0 wire. :?
Can anyone explain this discrepancy and/or if this is a common occurrence....the NEC and other sources being so out of sync with one another?
Many Thanks for any Answer.
Smatthew
Smatthew
