confused:
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
The voltage.
A continuity test applies the battery voltage to the circuit, any where from 1.5 to 9 volts.
A megger applies hundreds and sometimes over a thousand volts to the circuit.
electricalperson
massachusetts
a megger will tell you if the insulation is bad causing intermittant problems such as breaker tripping and a continuity tester will just tell you if there is no resistance between the 2connections such as checking a single pole switch
electricalperson
massachusetts
al hildenbrand said:
The voltage.
also what he said. and dont grab the leads while using a megger :grin:
brian john
Leesburg, VA
A continuity tester should be utilized to located and isolate shorts in wiring and never used to to test cables or any distribution equipment for possible shorts.
A megger can be used for predictive maintenance if utilized when equipment is new to establish a base line, then periodically for tracking equipment insulation values at a point based upon company standards or published standards the equipment can be slated for replacement prior to failure (in theory).
A megger will show a short from carbon in a fault distribution equipment a continuity tester won't unless the equipment is so trashed it is visibly obvious.
In the picture below a continuity tester would show no fault the megger shows issues.
Standard school paper, pencil lead (carbon), 1000 VDC test voltage
petersonra
Northern illinois
engineer
k billa said:
what is the difference between megging out and just doing a continuity check?:
Both are useful for finding shorts. A megger is useful for finding damaged insulation that is not to the level of a short yet.
Continuity meters use a very low voltage for their tests - something like 1 to 3 volts.
Meggers use a much higher voltage 500V or more.
k billa
thank you
thank you
i really appreciate the responses. i hope my classmates take advantage of this forum and use this information to their fullest.
