I am very pleasent to find this wonderful forum, by those old topics i learned so much knowledge. but there are still some question confued me. would you give me a hand? Your reply is very appreciated.
The question are : 1, how to size the bonding jumper of cable tray and conduit if i don't use it as EGC(i just bonding all cable tray section and those conduit connected to the cable tray, i'm confused if it is EGC when i bonding conduit to the cable tray), all equipments have their own EGC cable respectively) according to NEC code, may i use the minimum size 14AWG as bonding, if not, what could i take into account?
2, how to size the cable bonding the cable tray to grouding, i think it as EGC cable and choose the size according to table 250.102 by the maximum phase conductor in the cable tray, is it right?
3, if the HV panel and the transformer are in different location i means two different building in plant and i run the HV cable which belongs to clients to transformer room by cable tray, it means in the transformer room two different voltage level cable tray exist, shall i connect these two tray to the same gronding, if so, how to size the grounding cable to the HV cable tray.
4, if outdoor oil tank exists and i design a static-electrical discharge gronding system for it, the power panle feed by power cable with egc conductor is in this area, shall i connect the dedicated grounding system to the PE of panel?
