The main disconnect has 4 meters and runs to 4 subpanels. It has 1 ground rod in place but the lug is rusted and cannot be removed. Can I add another acorn the existing ground rod to attach the second??
I assume you mean the lug in the meter/panel is what is rusted.
A proper ground rod clamp is bronze and should not rust
Can you replace the lug/buss in the meter/panel or use a different slot?
Is this the primary GEC or is it a supplemental electrode?
If you have a water pipe electrode it is the primary GEC, any ground rods are supplemental.
Yes. The new wire becomes a jumper, which does not have to be the same piece of wire as the GEC, nor share the same clamp.bottom line is can i put a second acorn on the first rod and then add the second rod?
If you want to play with words then I would say the second rod supplements the first rod. So what do you call that? A supplemental supplemented rod or, as you say, a supplemental augmented rod. :grin:Only the first rod is supplemental. Any others augement the first rod.
Splitting hairs again. Good thing I like to argue also.![]()
I am not arguing that it is the augmented electrode but I would also consider it a supplemental rod just not the primary supplemental rod.
Nope.Dennis
Is anyone listening to us?![]()
My read on the matter is the second rod is always an augmenting electrode, but the first rod can be either a plain ol' electrode...I am not arguing that it is the augmented electrode but I would also consider it a supplemental rod just not the primary supplemental rod.
what does 110.12 (B) have to with a grond rod being deemed effective " come on man"
it's not the acorn that is rusted it's the lug inside the disconnect. bottom line is can i put a second acorn on the first rod and then add the second rod? sorry about the confusion, i think i may have worded it funny
