Electron_Sam78
- Palm Bay, FL
Hey all just want your input on connecting a pump house motor 200 hp 460v 3 ph with availability for connecting in PWS, Delta Run, or Y Start. It has a motor control center with a Altistart 48 Y-Range soft starter. The supply power is 480 Y system. My question is would this be connected in the Delta configuration when using the Altistart 48? There are 4 motors in the pump faciIity, which is a standby facility where the pump systems only get exercised weekly for 10 mins, and 2 have burned up in 5 years. They are currently connected in the Delta Run configuration. Seems like a high burn up rate.
Sent from my SCH-I435 using Tapatalk
