I am checking the compatibility of a UK rated 3-wire 230vac spa to a US GFCI. They use a blue and brown wire for their hot lines and ground however, they don't use a neutral leg. I've connected the spa pack and all the equipment works fine but I'm not sure if I'm going to get a low level power leak back to the water. Also, will it detect a ground fault without the neutral connected? In my experience, you can run some equipment without a neutral leg as long as the neutral is ran from the main panel. Any info would be appreciated.
