Connecting EGC to GEC
flynnk
New member
I want to install phone service in an existing home that has no existing phone system. According to the phone company, I must provide "a ground" for the phone junction box. I assume this comes from NEC 800.100, and that this would be a 'grounding conductor, equipment.'
I can easily install #6 wire in conduit from the location of the phone junction box to the crawlspace under the house. Unfortunately, it would be difficult to run to the service entrance panel. However, I could use a C-clamp to attach directly to the grounding electrode conductor, which is readily accessible in the crawlspace.
My questions are as follows:
1. Is 800.100 the appropriate article for phone system grounding?
2. Am I correct in interpreting the 800.100 as an EGC ?
3. Does the NEC allow connecting an equipment grounding conductor directly to the GEC rather than connecting at a panel?
4. Does the NEC allow connecting anything at all to the GEC? (I ask, since I noticed the GEC is also serving as a bond across the water heater . It is clamped to both hot and cold pipes where it passes by them on it's way to the water pipe inlet location near the street).
Thanks.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
Chris
