Connecting Multiple Large Conductors
rhenders
Alabama, USA
What is the proper way to connect three #4 copper conductors in a junction box? I have a generator (208 / 3 Phase / Wye) with the neutral or center conductor grounded. The generator is supplying power to a VFD/Pump through a large breaker. I'd like to tap into one phase downstream of the breaker to supply power to a 120 V light. Obviously, I'll need to use a junction box and some type of approved connector to connect the generator to the equipment and also to the 120 V accessory (much like a make-up in a residential switchbox - only larger). This will effectively form a "tee" in the #4 conductor. I haven't found a good way to connect all three conductors of this size (or larger) in a junction box. Wire nuts are too small (and probably not wise) and the lugs I find at the electrical supply houses are designed for bare ground conductors - no way to insulate them from the junction box. Is there an industry standard or acceptable part for this? I definitely don't want to use a bolt splice and tape it up! Thanks.
Polaris lugs are great for that. They come in many size and ports
looking through my Burndy Catalog for you... lots and lot (litterally tons) of electrically sound options
VERSI-POLE?
VERSI-POLE? 1, 2, 3 POLE
DISTRIBUTION BLOCKS
VERSI-POLE?
POWER DISTRIBUTION BLOCKS
VERSI-POLE? Power Distribution Blocks
are designed to provide modular solutions to
power distribution applications. Each connector
element is made from a high conductivity
aluminum alloy which is insulated with a high
strength polymer housing. One, two, and
three pole versions available. "Add" a pole
(snap-together) blocks are also available for
wire sizes up to 500 kcmil. For use with Cu or
Al. 600 V, AL9CU rated.
SPEC-BLOK?
POWER
DISTRIBUTION
CONNECTORS
T-CONNECTOR
TYPE NYT
CABLE RUN ? CABLE TAP
TYPES YST
UNINSULATED ?T?
COPPER HYTEE? COUPLER
UL Listed 90? C,
600 Volts to 35 kV?
TYPE VT
VARITAP? T-CONNECTOR
For Copper Cable to Cable
TYPE E-C-G
TRANSFORMER
TAP ADAPTER
TYPE UCU-AC
RISER TAP
TYPE BIPC
UL Listed 90? C, *600 Volt
Thanks
Thanks
Thanks all. Polaris did the trick!
VERSI-POLE?
DISTRIBUTION BLOCKS
VERSI-POLE?
SPEC-BLOK?
POWER
DISTRIBUTION
CONNECTORS
T-CONNECTOR
TYPE NYT
TYPES YST
UNINSULATED ?T?
UL Listed 90? C,
600 Volts to 35 kV?
TYPE VT
TYPE E-C-G
TRANSFORMER
TAP ADAPTER
TYPE UCU-AC
RISER TAP
TYPE BIPC
