Connecting Portable to Fixed
Hello, I have a Portable dimmer rack that needs to attach to an installed grid. The Building connect is a 5W 3phase 208V CamLok. So the Grid feeds will have the same ground and neutral as the disconnect. The idea is to have a J. Box with SO cable with standard 15A Edison Connectors hanging down. The dimmers have ind. 15Amp breakers per circuit. Are there special requirements for this type of install? Any suggestion are appreciated. Thanks
nvcape
Re: Connecting Portable to Fixed
The fixed installation should be inspected. If it's a small system, you can get UL listed pigtail boxes. If it's a larger system, you may not want that many cords and may want to use outlets, these are also available UL listed, surface or flush.
