Connecting Power Monitors
I'm working with a customer to install CutlerHammer IQ sentinels. He purchase the universal type, rather than the breaker specific ones. The breaker specific ones have tabs that go under the lug with the wire for voltage monitoring. The universal ones do not. The panels are loaded (no room for a breaker to supply a separate circuit for the monitors). Does anyone know if there is a "tab" or lug of some sort that would enable pulling the power from the load side of the breaker (similar to the breaker specific model) that is code compliant? I know that you cannot put two wires under a lug unless it is rated for such, but I'm curious to know if anyone else has encountered this.
PS. CutlerHammer tech support told me "good luck". They make these universal units so people can use them with Non CH breakers.
