pnovak22
- Long Island City, New York
- Electrical Engineer
Hello everyone,
I am new to this forum and have a question which probably has been discussed/addressed in a previous forum. If that is the case I apologize for the redundancy. It pertains to grounding terminal X0 on an isolation transformer. The application I am referring to is whereby an isolation transformer secondary (75kva, 460V delta primary/240V wye secondary) is connected to a static SCR elevator drive controlling a DC motor. The drive manufacturer suggests not to connect X0 on the secondary of the isolation transformer to ground. The electrical inspector insists that X0 needs to be connected to ground as per NEC. Looking at the NEC code I see section 250.20(B) alternating current systems of 50 volts to 1000 volts that supply premises wiring and premises wring systems shall be grounded based on the following conditions......then looking at 250.21(A)(2)(3)(a-c) indicates the following ac systems of 50 volts to 1000 volts shall be permitted to be grounded but shall not be required to be grounded and it appears 250.21(A)(2)(3)(a-c) applies to my application. The way I read this is that you can ground the X0 but are not required to. It discusses separately derived systems whereby the NEC mentions two of the most common sources of separately derived systems in premises wiring are transformers and generators. BTW, the code I am referencing is 2008 which is currently adopted where I work. I am sure I am overlooking something. Any insight would be greatly appreciated. Thank you.
