Connection of Aluminum Stranded Cable to Terminal Block
skhamis
New member
I need to Connect An Aluminum Cable 185 mm2 to Terminal Block PA66 Insulated and Tinned Coper Plated Current Bar. Cause of Two Different type of Material to Be Connected - Copper & Aluminum.
Pls advise.
Regards,
skhamis
the terminal block should be rated for aluminum.
it should be cleaned.
the conductor should be stripped without damaging the strands.
use a rated inhibitor like kno-lox to coat the aluminum exposed surfaces.
apply proper torque.
wiggle conductor --- re-torque.
finished.......................
