First, I would like to say, as a brand new reader of this board, and a 1-year veteran
of the Electrical Engineering field, that the discussions I read here are so helpful to me when I run across things I haven't had the time to learn yet.
Here is a problem I ran across the other day...no textbook I've had really tells me what is really going on. In a 3-phase so-called "consequent-pole" motor, i.e., a two-speed, two-winding motor, how is the field wired? I understand that it starts in a low-speed parallel-wye configuration, and is then switched to a series-delta configuration for high-speed operation.
My main question is this: Are the two coils that make up the series connection of a phase separated by mechanical degrees? I'm hoping I'm on the right track here. Wouldn't this make them act as a single pole when in series, but two separate poles when in parallel? (provided it is not a true parallel...the wiring diagrams show three of the six coils simply as an electrically isolated wye circuit...i.e, not connected to the phases)?
Anyway, I was hoping somebody who actually gets to tear some of these things down and wire them rather than just look at books all the time could tell me if I'm correct. Thanks.
