mshields
- Boston, MA
or for that matter in any kind of a room.
I sat through a seminar the other day in which the CRAC unit vendor stated that the amount of electrical energy going into the room in KW is equivalent to the amount of heat that needs to be removed from the room in BTU's (or however you measure it).
I would have thought that the heat generated is associated with the efficiency of the equipment. i.e. if the equipment is 80% efficient then 20 of power going to the unit is converted to heat. The other 80% is used and performs work.
Which is true?
thanks,
Mike
Which is true?
thanks,
Mike
