Constant current led driver
Mustwin351
Texas
I was looking for a low cost solution to replace the driver listed in the specs below to drive the led panel in parenthesis. or any different ideas of how to drive it.
HW-12-870012LED (for 8w LED Panel)
Output Power:
8w
Input Voltage: Output Voltage:
12v to 24v AC 12v DC
Output current:
700mA
Dimmable: Potted: Yes Case: PVC
No
Dimensions:
.875" OD x 2"
Input wire size: Output wire size:
18 AWG 18 AWG
Input wires color: Output wires color:
Black (no polarity) Red ( + ) / Black ( - )
Installation:
Direct Burial Rated
Warranty:
5 years
So...
do you have 12vac or 24vac? That would make a difference as to a solution.
If you have 12vac, you should only need a rectifier
So...
He needs a constant-current LED driver. This driver meets the electrical requirements:
http://www.ledsupply.com/led-drivers/buckbullet-ac-led-driver
I have used that series of drivers and they are really good. It is potted, but not direct burial rated and since it's essentially an OEM part it doesn't have a meaningful warranty. I would direct bury it after coating in Scotchkote and wrapping with rubber tape though.
