This may help.
Think in terms of
Constant Horsepower and
Constant Torque.
1 Horsepower is the amount of force required to lift 550 lbs 1 foot in one second.....or 33000 lbs. 1 foot in one minute.
These values were determined by actual tests using a horse (or a number of average horses).
http://www.web-cars.com/math/horsepower.html
Any combination of the lifting speed and weight are accurate as long as the same amount of work is accomplished. ....such as...
It takes the same amount of work to lift 1 pound 1 foot in 1 second as it does to lift 2 pounds 1 foot in 2 seconds, or 2 pounds 1/2 ft. in 1 second....etc.....get the idea?
It's all in the amount of work done verses the amount of time required to do the work.
Constant Horsepower is the amount of work required to do this amount of work continuously....such as a electric motor pulling the same load continuously....it's delivering constant Horsepower.
Torque is a measurement of turning or twisting force around a axis.
1 lb/ft. of torque is the amount of twisting force applied around a axis that has a lever of 1 ft and a applied pressure of 1 lb....my wording.
Say that you have a wrench that is 1 foot long attached to a shaft, and you apply 1 pound of pressure to the end of the wrench.
You are applying 1 lb./ft. of torque to the shaft.
If you keep applying the 1 pound force constantly....You are applying 1 lb./ft. of
Constant Torque to the shaft.
It doesn't matter if any work is performed...it is merely a measure of force..either instantaneous, intermittiant or constant (as in the example).
Motors rotate (no pun intended)....so the force that they generate in order to do work is torque.
In the HP example above, since the Motor is delivering a constant amount of work (constant HP)...it is also at the same time delivering constant torque to it's output shaft.
If for example I half the load to .5 lbs. and double the lift speed to 2 feet per second...the required torque on the shaft would remain the same.
If I double the load to 2 lbs. and the lift speed remains 1 foot per second, the Horsepower required would double and the torque required would also double.
These are my own opinions, and were arrived at by actually working with motors and loads...so the terminology may not be entirely accurate.
I didn't learn this from a book.....well maybe some of it.:smile:
Feel free to analyze...and correct me if I'm wrong.
I'm here to learn.
steve
