jackman435
- Fort Dix, NJ
We are hooking up a 100amp, 1 ph 120/240v load center in a trailer on a const. site. We are installing a 100 amp fused NEMA 3R disconnect on a pole 10' from trailer. We will use USE to feed the load center. My question has to do with grounding. Does the Load center require an isolated neutral bar, with neutral going back to disconnect, and a ground bar with EGC also going back to disconnect? Not sure if this should be treated as a subpanel.
