consumtion CTS Compatible main meter combo Panel
Designer101
California
Solar and ESS Designer
Do you guys know any main metr combo Panel that has wires accessible to install consumtion Cts between the meter and main disconnect.
something likes this will also work but the bus bar rating shoud be 225A
All square D Solar ready home line panels have easily accessible bus bars that will fit CT’s no problem.
Eaton panels also usually work if they have a CSR main breaker.
A side by side model like what you’re showing are always nearly impossible, the parallel wires coming from the meter socket to the disconnect are too tightly grouped for CT’s to grab.
