titan1021
- Northern California
I need to install a small 3 pole contactor to allow On/Off switching of a 2.7 amp 3phase motor with a 2-pole switch. This will be a non-typical installation, ie.. custom for this client.
The load is 3 phase 208v. I was planning to use a 3 pole contactor with a 208v coil then basically pig-tail off of two of the line legs, terminating one set at the coil and one to the line side terminals of the contactor. I haven't done this before, but I don't see why it wouldn't work.
Just wanted to run it by a few folks and see if there are any considerations or potential issues that I may be overlooking here.
Thank you
Thank you
