dmc1701a
New member
- Grand Rapids, MI, US
I have an exhaust fan starter that I'm having troubles with not staying engaged, rather it cuts in and out like a slow heartbeat. with this EF there is a motorized backdraft damper that is operated by a 24v actuator . To get this 24volts I have installed a 480 to 24v 40VA transformer which is tapped off the 480v's from the line side of the contactor same as the 120v control transformer that came with the starter. on the damper actuator there is an end switch that will make once damper turns to at least 80 percent open(proof that EF will be sucking air). attached is a rough sketch of what I have wired. any thoughts on what might be the cause?
