Contactor for A/C disconnect ? Really ?
titan1021
I am providing power and disconnects for a Fugjitsu 240v 30a split system A/C being installed in a Ice Cream Shop. The indoor unit is mounted up on a wall and recieves power via (3) wires that come from terminals inside the outdoor unit. The wiring diagram indicates that all (3) wires need a disconnect for the inside unit. I've ruled out a 3 pole disconnect for the inside because of its size and appearance(visible to customers), and I've never seen a 3 pole switch. The best way that I've come up with is to install a 3 pole contactor with a 120v coil in the attic, then I can just put a toggle switch on the wall next to the unit. This would look the best, but it seems like overkill to put a contactor in for a small A/C. I just can't believe that people are having to put in large 3 pole disco's or contactors for these popular units.
Just wondering if anyone has any better ideas.
Thanks
First you can not use a contactor and a control circuit as the disconecting means so rule that out.
You can get a 3 pole 30 amp switch that looks a lot like a normal switch.
You can use the factory enclosure or it can fit in a large device box, I would use a 4" square deep box with a single gang raised ring if I was doing this as new work.
They make 3 pole toggle switches, my supply house carries them. They're a little big to fit in a handybox but will fit in a 4 sq with a raised cover just fine.
I have where possible put a standard 2 pole toggle switch on the wall beside the indoor unit that feeds the outdoor disco and unit.
I know that is not exactly how the directions say to do it but it serves the same purpose.
But would the switch controlling the coil for the contactor be the means of disconnect?
What code section is that in? I'm looking and I don't see it. Unless you are
talking about 440.63 (2) and your saying a contactor and a control circuit
would not be a "Approved" manually operable disconnecting means.
I'm not doubting you ,I just would like to see it in the NEC.
PLease tell me what code cycle. I have 99,02,05,and 08 in arms
length. Thanks
i agree with bob
29 CFR 1910.147
Energy isolating device. A mechanical device that physically prevents the transmission or release of energy, including but not limited to the following: A manually operated electrical circuit breaker; a disconnect switch; a manually operated switch by which the conductors of a circuit can be disconnected from all ungrounded supply conductors, and, in addition, no pole can be operated independently; a line valve; a block; and any similar device used to block or isolate energy. Push buttons, selector switches and other control circuit type devices are not energy isolating devices.
