I'm re-designing an emergency system backed up by a generator that contains a normal-emergency panel and an emergency-only panel. Many older installations I've seen use a typical lighting contactor to energize the emergency-only panel when the generator transfers to emergency. My question is, for new installations, does this contactor need to be listed for emergency use? Article 700.25 almost leads me to believe it does, however I haven't found any larger contactors/relays (>50A) that are listed for emergency use. One-line attached for reference.
