- Wisconsin
- PE (Retired) - Power Systems
I am pretty sure your engineering school taught you about punctuation, your post would be more readable if you used some.Try looking at grainger with my degree in electrical engineering I could get a two pole 50 amp contacter and two ice cube relays two switch back and forth from nc to normally open as needed for the system to work properly again I would have to open the inverter and solder a few wires
Are you using the adjective 'normally' to mean a device's unpowered state (the traditional meaning) or its most common operating state (a non-traditional meaning)?
It appears you are encouraging someone to change the internal wiring of a 'listed assembly'.
