Container Cannabis Extraction
Have a question where at California
a customer trying to install a cannabis extraction container on our opinion this has to be wired as per Hazardous location conduit and wiring, Fire Chief never mentioned where is required the installation of hazardous classified location we need update from your experience.
It depends. From what I've seen, some use water or other non-volatile solutions in the extraction process, some use oils and some of those can be volatile.
Butane, for example, is both volatile and flammable.
It also seems to be the general solvent of choice. Some enterprising chemist/chemical engineer could make a mint developing a CO2 extraction process. Super-critical CO2 extraction itself is old-hat technology.
Depends on if they are using CO2 or hydrocarbon extraction process. If it's CO2 then I don't think it is a hazardous location, depending on the flammability of the other components but hydrocarbon definitely is. Code and standards development is in its infancy in this area. The NFPA Journal had a good article on the subject many months ago and you might want to look it up. The AHJs in Colorado have developed some standards in this area that might be adopted nationally in the future, worth looking at.
cannabis extraction
cannabis extraction
Thank you this a good information.
