millstrainer
The code requires the grounding electrode conductor (GEC) to be continuous without splices, except for irreversible ones. Where is this grounding electrode conductor starting at on a separately derived system? Does it have to be continuous from the X0 lug, a ground bus, or the case ground? We install a single point ground bus in our transformers and everything (jumper from X0, equipment grounds, grounding electrode conductor, etc)is connected to it in set screw type lugs. Is this type of installation acceptable since the GEC has a break in it (at the grounding bus) between the grounding electrode and the X0 lug.
