I had to check some work being done at church, so I started at the lighting panel . It was being fed from QMB panel. So being fed from this QMB panel would make this a sub panel. So I had them remove the bar tiring together the neutral and ground bar. I check with my and I still had continuity between them. Is this right, I would expect them to be separate.
