ken44
- Austin, TX
I have a 30kva xfmr being fed from a 1200 amp bus on a multi story commercial building and the xfmr supplying a 225 amp panel .
Does an EGC have to be continuous at the main service, in other words, can there be a continuation of the ECG by means of a ground lug, split-bolt or other similar means?
My inspector tells me that the wire must be continuous through XO to case or as an alternative, I must ground my neutral bus to the panel can.
One of us is confused, Can you please help?
