Does any one have a form that a contractor can fill out stating what items are included in the structure prior to me estimating a set of drawings. I usually ask about tub motors, etc. when estimating and over the past few houses [new contractors due to the economy] I have been told no or did not recieve an answer. Now that the project is underway one is being installed and a change order was put in. I am being told I should have accounted for one since it is a larger home [3800sq'] and supposedly this is what the sq' guys do; along with not charging for door jamb switches if the framing requires a change from the standard switch shown on the wall.
We usually itemize quite a bit and the sq' thing doesn't seem to be working very well. We even had one competitors proposal including ceiling fans and structured wirring in the base price [I saw his actual numbers and had to let that job go, no way I could compete with that] below 14,000 for a 3500sq' home on the ocean.
It may just be the builders are taking advantage of the new guy, but It still sounds like a good thing to have on hand.
Thanks in advance,
Thanks in advance,
